LS6 Heads milled .030 with comp cams cam what pushrods?
Is there any guide that you can use to determine pushrod length? I have .030 milled LS6 heads on my corvette and wondering if the 7.400" stock pushrods can be used?
Phillip <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" />
I have milled heads the same as you but I have a thunder cam. It required shorter rods. 7.350 to be exact.
<small>[ August 28, 2002, 07:35 AM: Message edited by: 5-liter-eater ]</small>
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Smoke_ur_5.0:
<strong>You should switch to 7.350's as mentioned earlier.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What determines this? I'm getting MTI S2 heads, C2 cam, and they're only going to be milled about .010, and they said go with stock length?
-Dave
-Dave
