broken spark plug in motor, need advice
Old 03-12-2007, 10:32 PM
nofxrxmxpx's Avatar
Default broken spark plug in motor, need advice
i bought a motor... it has some bosh +4 bullshit in it.. i was putting the long tubes on it so i took the plugs out (was changing them anyways) and one of the plugs is completly stripped of the electode and the 4 tabs.... i am going to compression test it by hand tomorow, if it checks out ok is there any methods i can use before i go tearing the whole motor down? any help would be awsome, thanks guys
Old 03-12-2007, 10:33 PM
brad8266's Avatar
pull the heads
Old 03-12-2007, 10:35 PM
nofxrxmxpx's Avatar
i knew this was gonna happen!!
i have such bad luck, i feel like im going backwards on this project.
Old 03-13-2007, 01:38 AM
XofXtimeX's Avatar
Trust me. I never feel like it's a project if I don't go backwards atleast twice during the whole procedure.
Just me putting suspension on I'd have new **** break on me and I had wheel studs break.
Old 03-13-2007, 01:41 AM
3.4camaro's Avatar
maybe you got lucky and it got pooped out, no damage. why would you pull the motor apart?
I wouldn't do anything cept put in some NGK TR-55s if there are no symptoms cept a broken plug.
Old 03-13-2007, 02:37 AM
nofxrxmxpx's Avatar
idk what to do.. what would you guys do if it was urs?
Old 03-13-2007, 05:07 AM
vettenuts's Avatar
Not sure I understand what broke. Is the center ceramic core of the plug out of the motor and the threads/lower tip still in the spark plugs threads of the head? I had this happen once a long time ago.
