my 228/232 cam
I would get either HPT or EFI Live and go at it. Both of their respective forums have tons of info and very knowledgeable people to help out. You pick up a lot of things just by reading
Honestly my suggestion would be to buy HPT and do a log. You will get support from a lot of very good tuners. You post the log up and some will tell you whats wrong with it and others will actually fix it for you and post it back. My suggestion would be to learn how to tune so for future mods of problems you can fix/tune for yourself.
You are probably getting tired of the same answer.
I'm with Predator-Z.
Speed Inc will set you up. I've had great work done there.
Incredible cam. Mine idles perfectly at 775rpm. None of the issues you are describing.
I just chose to have it professionally tuned (TSP).
Don't give up.
Good luck...
SSpdemon... what is the difference between EFI Live and HPT?
Is it guranteed that you can fix my tune issues???
My guess is, your '02 is a lot like my '01 and we can at least get 'er close. EFI Live is pretty much like HPT in terms of access to tables. But, they aren't interchangeable any more. If you had a *.bin file copy of your tune, I could look at it. Otherwise, I'd need to pull it from the PCM.
Sorry guys.. i am giving up. i can not even drive the car w/o getting frustrated with it. Ohh and so far i am at 110 miles to the tank and i am jsut about 2 mm away from 1/4......
Sooooo after April 9th.... This cam has +/- 550 miles Still brand fuggin new
FS:
TSP 228/232 .588/.595 110+4
PRC Dual Springs
TI Retainers
7.425" Hardened PRs
FS:
PRC Dual Springs
TI Retainers
7.425" Hardened PRs
ehhh. i do not have the money for the SW. I think that my 02s are failing. The LTFT were +2 and +8.....
when the car was stock, it was still fun...
This is the most expensive Oil Pump, UDP and T-stat is history
FS:
PRC Dual Springs
TI Retainers
7.425" Hardened PRs
