Help w/engine choices 382 stroker/bore or 422 I want to do a bigger cubed motor over the winter. Originally I was dead set on a 382 stroker then I was looking at JPR's 382 all bore. Then the idea struck me to throw a stroker crank in the all bore 382. I loved the idea of having a 422. But....It's gonna be tough to save up 10 grand in the next 4 months or so. Is the 422 going to be that much better then either of the 382's? I plan on bigger injectors and and 2nd fuel pump either way. Also would like to keep my nitrous and throw a 200 shot evenutally. Just looking for ideas on the best setup for the money. I can do it all at once or add the crank later. Thanks |
Re: Help w/engine choices 382 stroker/bore or 422 cheaper to just do the 1st time, my 422 should be done in 5 weeks. I added LS6 heads head studs jesel rockers |
© 2024 MH Sub I, LLC dba Internet Brands
