jrp lifter holding tool, anyone make their own?
im doing a cam swap really soon but im not removing the heads, just swapping springs. this tool looks like it will hold the lifters for you easily and safely, anyone used it? to me it looks like i can hit up a hardware store and simply, buy a couple of pieces of metal rods. not being cheap but the tool looks a little over priced.
..to anyone that asks thunder racing sells them
Go to home depot and pick up two 5/16" aluminum dowels and cut them to 2 feet. They work a lot better than the flimsy wooden dowels and are only like 3-4 bucks for both.
I used 1/4" wood dowel and it did hold the lifters from falling in the motor. But, I should have used 5/16" because 1/4" keep them from falling out, but not from falling down some (I had to pop 2 of them in the back of the block back up). The added friction from the 5/16" dowel would have been a better idea. Anyway, I would use 5/16" wood dowels if it were me. If you are using pen magnets make sure they won't fall apart and that they are pretty strong, IMO.
Brian
Brian
