MS4 cam in 5.3L auto truck
Old 04-07-2007, 02:42 PM
jonnyboy's Avatar
Default MS4 cam in 5.3L auto truck
What is needed for this to work? (type of springs, tune, rod bolts, length of pushrods?)
Will LS6 springs work?
Will this be a good cam for a 5.3L auto in an ext. cab silverado (5500lbs) with 4.11 gears and a 2600rpm stall?
Thanks in advance for all the help.
Old 04-07-2007, 04:16 PM
CAMAROZ28AQUINO's Avatar
i dont know if it will fit but i know for sure that z06 springs arent enough for that cam....comp 921's are the ones to get, i believe
Old 04-07-2007, 04:28 PM
Grimes's Avatar
honestly, i think it will be too big for your heavy vehicle (compared to a car), even with the gears and stall. how about something like a torquer 2 or TR230?
Old 04-07-2007, 04:30 PM
slammedchevy's Avatar
that would be overkill for that
Old 04-07-2007, 04:54 PM
jonnyboy's Avatar
what are the specs and average hp gains on the tr230? i'm just looking for low 13's n/a, then i'll probably boost it via radix or turbo
Old 04-09-2007, 10:17 AM
mudflap1989's Avatar
Are you going to change the cam again when you add boost?
I suggest a smaller cam with that stall and as heavy as your truck is, it will suck down low.
Old 04-09-2007, 10:30 AM
5.3LJimmy's Avatar
That is way too much cam for a 5.3. Even the TR230 in my opinion is too big. Given the weight of the truck and the smaller displacement of the 5.3 I wouldn't exceed 224 duration. Even that may cost you some bottom end. This question would get better results in the truck forum.
Quick Reply: MS4 cam in 5.3L auto truck
