LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   What's my misfire from? (https://ls1tech.com/forums/generation-iii-internal-engine/69424-whats-my-misfire.html)
WhynotSS Dec 13, 2002 04:29 PM
I just got my car started after a horrible cam install. I dropped a lifter and had to pull the driver's side head. When autotapping it, I found misfires in almost all of the cylinders. There's probably about one every 20 seconds. This was all at idle.
Could it be that my fuel injectors are dirty? What could be causing the misfires?
66LS1NOVA Dec 13, 2002 05:05 PM
Re: What's my misfire from?
A MULTIPLE CYLNDER MISS IS MORE THAN LIKELY NOT DIRTY INJECTORS (ALL AT THE SAME TIME?) CHECK O2 SENSORS SEE IF THEY ARE SHOWING LEAN OR RICH AND GO FROM THERE, MOST LIKELY IS A VACCUM LEAK INDUCING TOO MUCH AIR INTO SYSTEM, HAS THE COMPUTER BEEN MODIFIED TO MATCH YOUR CAM? IF NOT THE PULSE WITH AT IDLE MAY NOT BE ENOUGH TO SUPPORT THE CAM CHANGE GOOD LUCK!!
WhynotSS Dec 13, 2002 06:45 PM
The misfires are only happening at idle so it must be a computer thing. Thanks.
wrencher Dec 13, 2002 10:40 PM
If you got a big enough cam that causes a lope at idle that will give you missfire codes.
© 2026 MH Sub I, LLC dba Internet Brands
