Anyone know the CC's of 241 heads milled to .035?
Old 04-12-2007, 09:23 PM
00 Freak's Avatar
Default Anyone know the CC's of 241 heads milled to .035?
Just as the title reads. Thanks
Old 04-12-2007, 09:25 PM
brad8266's Avatar
Around 57cc or 58cc.
Old 04-12-2007, 09:40 PM
00 Freak's Avatar
That what I was guessing also. Thanks!
Old 04-13-2007, 02:02 PM
Studytime's Avatar
That's too small. They'll be bigger than that. The size will be closer to 61cc range.
I've milled some 317 heads .030" and it only knocked off ~3.5 cc. The chambers are shaped differently between the 6.0L heads and the LS1 heads, but it's not going to be such a dramatic reduction in combusion space. For those 317 heads one cc was removed by machining off .0085" on average over the first .030" milled.
A .030" mill on a LS1 head is generally accepted as producing a 62cc chamber. Given some more time, I'll be able to post up my own findings on how milling affects combustion space on a 853/241/806 head.
In closing, milling .035" off a LS1 casting will not get you a 57cc chamber- I can say that. To get that small means you'd have to be removing around .004" to get rid of 1cc of chamber. More material has to come off the deck to get a cc off than that.
Ben T.
Old 04-13-2007, 04:46 PM
Beast96Z's Avatar
Subtract 1cc for every .007". That'll get you close.
Old 04-13-2007, 05:01 PM
Studytime's Avatar
That agrees with my post. You wind up with a chamber right under 62cc.
Ben T.
Old 04-13-2007, 05:05 PM
00 Freak's Avatar
Thanks man!
Old 04-13-2007, 05:06 PM
brad8266's Avatar
I stand corrected, I was thinking of the LS6 head, he has 241 LS1 heads. Yes it would be more like 60-61cc's. Sorry about that, i cant be perfect all the time.
Old 04-13-2007, 05:09 PM
00 Freak's Avatar
It happens.
Studytime's Avatar
Brad, when I read that I was thinking...
You are usually on your game time after time. I knew something simple had come up. Sounds good Brad!
Ben T.
Old 04-13-2007, 05:13 PM
brad8266's Avatar
Thats why we have a lot of people here that know their ****. So when one of us makes a simple mistake someone else will come along and correct the mistake. That way the person asking the question gets the right answer and doest mess their car up.
Old 04-13-2007, 05:18 PM
00 Freak's Avatar
See, you guys do come in handy.
Quick Reply: Anyone know the CC's of 241 heads milled to .035?
