Can some one figure out my SCR & DCR?
Old 04-30-2007, 05:02 PM
Moderator
davered00ss's Avatar
Default Can some one figure out my SCR & DCR?
I just installed AFR 205's Milled .030 with GM gaskets .056 compressed thickness. Running a TR224 cam 224/224 .563 lift on a 112 lsa. Stock shortblock.
Thanks,
Dave
Old 04-30-2007, 05:21 PM
pdd
pdd's Avatar
Thanks,
Dave
whats the head gaskit bore size, how much do the pistons come out the hole.how much advance in the cam. whats the degree at .006 for thunder racing cams?
i used 50 degree's at .006, with the cam at +4 and -.008 out of the hole and a head gaskit bore size of 3.910 i get 11.05 scr, 8.77 dcr of course its all a estimate till i have all the correct info
Old 04-30-2007, 05:26 PM
Tainted's Avatar
hate to hijack a thread, but whats the formula for calculating all that stuff? Id lvoe to know how to do it so I wont have to ask it in the future myself.
Old 04-30-2007, 05:28 PM
pdd
pdd's Avatar
i use a compression calc. jrod has a nice on on this forum. i use the one from pat kelley. i like that one the best
Old 04-30-2007, 05:52 PM
Moderator
Old 04-30-2007, 07:53 PM
LS1TECH Sponsor
badpewter-z's Avatar
probbly in the 10.5-10.7 range dave , the dcr im not sure on . don has the so???are at his house but idk the exact specs for the setup
i know what mines at
Old 04-30-2007, 09:54 PM
ls2 bait's Avatar
i get 11.16/ 8.46 assuming no advance in the cam and a 60cc head.
Old 05-01-2007, 11:08 AM
Moderator
Chamber is 61cc with the .030 mill.
Old 05-01-2007, 12:14 PM
PREDATOR-Z's Avatar
That cam is a +4 and .006 is 275 (actualy 274.6)
Old 05-01-2007, 01:15 PM
Moderator
Still confused, but I think I got the SCR 10.84. I'm not sure of the # because I did not know the stock piston & block height #'s.
Old 05-01-2007, 01:29 PM
Moderator
Ok, with pistons out of the block 0.008 I get 11.06 SCR?
Old 05-01-2007, 02:12 PM
Irocss85's Avatar
my pistons were .006" out of the block. seems your using the upper end of the range for out of the hole average. hope this helps get a more realistic #.
Old 05-01-2007, 02:33 PM
Moderator
At .006 it comes out to 11.0 So 11 is safe to assume.
