LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   918's or PRC duals? (https://ls1tech.com/forums/generation-iii-internal-engine/719071-918s-prc-duals.html)
01redws6ta May 22, 2007 09:28 PM
918's or PRC duals?
I'm getting the 224/228 .581/.588 (110+2) cam and the vendor said that the 918's would be plenty sufficient with stock retainers. I was planning on getting the PRC dual kit. I thought someone on here mentioned that the duals should be used with the XE-R lobe cam (Patrick G). Anyone run a cam like this with the 918's and no problems? :drive:
bigdsz May 22, 2007 09:33 PM
The 918's will work just fine, however I just like the added security of the dual spring.
01 BERGER CAMARO SS May 22, 2007 11:27 PM
I have the PRC's and no problem here.
bursty May 22, 2007 11:57 PM
With all the problems with 918s lately, I wouldnt push them. Duals for me.
Boosted 99 TA May 23, 2007 01:14 AM
what has been goin on with the 918s thats what im runnin wtih my cam and havent had any problems yet.
vettenuts May 23, 2007 05:15 AM
Any more specifics on the can (lobe #'s or something)?
You could use either spring, I like the beehive design myself but the 918's did have some recent issues although Comp doesn't seem to acknowledge it anymore. The PSI 1511 is also an excellent beehive spring and is nitrided for long life.
badpewter-z May 23, 2007 10:50 AM
918's would be sufficent but the duals would be better and give you a tad more sercuity/piece of mind
GuitsBoy May 23, 2007 12:06 PM
Duals add safety for not too much more cash. And youre not in any danger of "over springing" like some people state.
bursty May 23, 2007 02:26 PM
http://ls1gto.com/forums/showthread.php?t=159887
Pics are down but basically completely trashed his motor over a broken 918.
01redws6ta May 23, 2007 08:49 PM
Thanks alot for the input guys, I think I'll probably go with the dual springs then.
staringback05 May 23, 2007 10:59 PM
prc and then just dont worry about them
© 2026 MH Sub I, LLC dba Internet Brands
