Can I use NGK55's in a Dart Head? Just got my dart heads in and wanted to know if NGK55's are OK to use? Bill :chug: |
Supposedly you can use either tapered or gasket plugs. I went with the gasket plugs. There is a couple of old threads on this if you can find them, where Dart came in with some recommendations. Katech recommended the Denso Iridium's, that's what I went with in the end. |
Originally Posted by vettenuts Supposedly you can use either tapered or gasket plugs. I went with the gasket plugs. There is a couple of old threads on this if you can find them, where Dart came in with some recommendations. Katech recommended the Denso Iridium's, that's what I went with in the end. Bill :chug: :drive: |
© 2024 MH Sub I, LLC dba Internet Brands
