How to install Harland Sharp 1.7's?
Old Jun 1, 2007 | 02:21 PM
TheLS1Kid's Avatar
Default How to install Harland Sharp 1.7's?
I tried a search but could not find an exact answer.
Do I install them just like the stockers and tq to 22ft/lbs?
Thanks.
Old Jun 1, 2007 | 02:39 PM
RZRSEDGE's Avatar
Yeah, just take the aluminum guides out from under the stock rockers and use the supplied pedestals and do the same sequence as factory. When I did mine, I found an aluminum sliver sticking out of one of my new HS rockers. Went through all of them carefully looking and found three more pieces. I pulled them out with a pair of tweezers. One of them was almost an inch long! I know it was'nt in your question; but I wanted to give you a heads up as to not do any internal damage. Good luck!
Old Jun 1, 2007 | 02:42 PM
onebadZ28's Avatar
The LS1howto.com has a really good write up along with a lot of other installation walkthroughs. Good luck with the install. let us hear about your results.
Old Jun 1, 2007 | 03:30 PM
TheLS1Kid's Avatar
Appreciate the responses guys.
Thanks for the heads up.
Old Jun 1, 2007 | 05:11 PM
teke184's Avatar
make sure the rear of the rocker (pushrod end) doesn't touch the inside lip of the valve cover gasket surface. mine did just slightly. had to take a file and remove a VERY small amount.
mine went in very easy
Old Jun 1, 2007 | 09:12 PM
TheLS1Kid's Avatar
Cool.
Thanks for the tip teke184.
