ETC vs non-ETC intake on 4.8/5.3
I purchased a non-ETC engine with an ETC intake.
I was under the impression all that I needed to do
was swap the throttle body and injectors. Tonight
I was attempt to swap the TB, and found this...
Does it mean I *do* need to get a non-ETC intake?
I have the non-ETC throttle body and injectors, will
I need to get *anything* else besides just an intake?
Thanks!
Thanks!
Just take some pliers and roll the tube down on the throttle body enough to clear the one on the intake, it will move w/ a little pressure. Then pick up a rubber vacuum cap from an autoparts and plug it off. Plug the hose from the front of the valve cover into the tube on the intake and your done.
And I would stick w/ that intake b/c you don't have to worry about blocking off the EGR port. Good luck.
