Comp 918's I searched and I couldn't find anything, so I just thought I'd ask. I thought I remembered reading a month or so ago that people were have problems with the 918's. Is this true? Has this problem been resolved? I searched and all that I could come up with is back in 2002/2003 when they had a "bad batch". Or maybe I'm just crazy?? |
Keep searching, this is one of the recent ones. https://ls1tech.com/forums/generation-iv-internal-engine/692113-prepared-lose-sleep-over-beehive-918-s.html |
Yea, there have been some recent issues since they swapped manufactures. I had a set & didn't want to roll the dice so I sold them. Went with Patriot duals instead. |
Crane is now making a beehive spring as well, you might want to check them or PSI 1511's. |
Originally Posted by vettenuts Crane is now making a beehive spring as well, you might want to check them or PSI 1511's. We've also come out with the next evolution of the 918 which is our PAC-1518. Capable of .650" lift. Its nitrided and gets a lot fo the same processing Cup springs get. I believe Crane sells this from us too but I don't know their part number off the top of my head. This and the Patriots duals are very good springs. |
i wouldnt use 918s if you paid me...just NOT worth it E |
Originally Posted by Yeahdoug The crane beehive is made by us and we made the original CC 918s. So the Crane beehive is actually the original 918 :) We've also come out with the next evolution of the 918 which is our PAC-1518. Capable of .650" lift. Its nitrided and gets a lot fo the same processing Cup springs get. I believe Crane sells this from us too but I don't know their part number off the top of my head. This and the Patriots duals are very good springs. |
Originally Posted by vettenuts Good information. So the Crane beehives are nitrided? |
There's a group purchase going on the pac 1218's and 1518's on cz28.com $120 shipped for the 1218's shipped and $200 for the 1518's. |
My 918s work just fine. |
Wow, I thought the 918's were a decent spring. Thanks for the info guys. I will probably end up going with PRC Dual Springs from Texas Speed. |
Originally Posted by erikthegoalie i wouldnt use 918s if you paid me...just NOT worth it E |
Originally Posted by 97MysticZ Wow, I thought the 918's were a decent spring. Thanks for the info guys. I will probably end up going with PRC Dual Springs from Texas Speed. |
My 918's are fine also. |
no problems with my 918s.... |
Mine are holding up just fine so far. |
Originally Posted by Yeahdoug They were when we made them. And they still are, just with a different part number :jest: |
| All times are GMT -5. The time now is 03:56 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
