LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   Broke ARP head stud on Smokinhawk's car -- Ideas? (https://ls1tech.com/forums/generation-iii-internal-engine/75565-broke-arp-head-stud-smokinhawks-car-ideas.html)
Reckless May 17, 2003 05:02 PM
Putting some new head gaskets in. Since he is running higher boost, I decided to go 80 pounds on the 3rd torque pass. First stud we hit snapped under the brutal torque of Jonathon's incredible strength ;)
I was very surprised to say the least. Now gotta figure out how to get it out. Gonna try an 1/4-inch, 8mm socket as a guide in the hole. Then use a bit through the socket to drill into the stud hopefully. Then try the easy out. If I can't get it, I guess I will pull his motor and take it to the machine shop.
Anyone else broke an ARP stud? Will they replace it?
:mad:
NB99Z May 17, 2003 06:09 PM
Re: Broke ARP head stud on Smokinhawk's car -- Ideas?
If you have a mig welder its very easy. Start welding on the center of the stud(weld a little ball let it cool for 30 sec weld a little more ect.)until its tall enough to grab with vise grips then turn it out with the vise grips. The weld will not stick to the aluminum.
Reckless May 18, 2003 09:36 AM
That is a great idea, but the stud broke off about 3 inches down into the hole. The method I talked about worked OK. Got the pilot hole started with the socket in there. Then used a larger bit to bore down a bit. Then a long 3/16" bit to bore some more. Got the easy out in and it broke right loose.
I will remember that for next time though if the bolt breaks off closer to the surface. :D
NB99Z May 18, 2003 11:03 AM
Glad to here you got it out. I sure there was a lot of happy faces when it backed out.
MIGHTYMOUSE May 18, 2003 11:51 AM
i'd pull all the studs out and send em to arp for inspection/replacement.. thats just not right.
© 2026 MH Sub I, LLC dba Internet Brands
