What's the best cam for a 427 stroker.... This is my daily driver. It must retain A/C use, excellent driveability, good starts (hot and cold), and make the most power it can by attaining to these must haves listed prior. Car is MN6 and here's what the heads flow (not bad eh ;) ): [image]http://users.ev1.net/~ynot_dv8/flowLS6.jpg [/image] I currently run an R1 cam, 232 236 .575 .578 114 Let's see your input! |
Re: What's the best cam for a 427 stroker.... 2002 LS6 cam. ;) |
Re: What's the best cam for a 427 stroker.... Why not try a G5X2 ;) |
Re: What's the best cam for a 427 stroker.... I read in a post that MTI is trying a new cam in the 236/236 .595 range for their strokers. Maybe that would better suit your taste. |
Re: What's the best cam for a 427 stroker.... The cam you're running jnow is pretty small for a 427, are you wanting to go bigger and still maintain driveability, keep the lsa at 114, but up the intake/exhaust duration. The cam I have in my 388 is a 243/250 .610/.612 114 and it idles like a champ, I pulled the a/c so I don't know how it would do but I'm sure with tuning it would be fine. |
Re: What's the best cam for a 427 stroker.... Im building a Alum Block 409 and I am looking at the Lunati 242/242 .595 112. Seels for $345 :hail: If not Comp has a Catalog in the mail to me, so I will look around in there. I think you need to START looking at the 242 range and go up from there. I have the same criteria as you, except I have an A4. Good Luck. |
Re: What's the best cam for a 427 stroker.... From experience I can tell you that the Comp Cam 242/242 - .612/.612 will idle and drive without issue. |
Re: What's the best cam for a 427 stroker.... Keep em' coming. |
Re: What's the best cam for a 427 stroker.... This is my daily driver. It must retain A/C use, excellent driveability, good starts (hot and cold), and make the most power it can by attaining to these must haves listed prior. Car is MN6 and here's what the heads flow (not bad eh ;) ): [image]http://users.ev1.net/~ynot_dv8/flowLS6.jpg [/image] I currently run an R1 cam, 232 236 .575 .578 114 Let's see your input! Dan :drive: |
Re: What's the best cam for a 427 stroker.... This is my daily driver. It must retain A/C use, excellent driveability, good starts (hot and cold), and make the most power it can by attaining to these must haves listed prior. Car is MN6 and here's what the heads flow (not bad eh ;) ): [image]http://users.ev1.net/~ynot_dv8/flowLS6.jpg [/image] I currently run an R1 cam, 232 236 .575 .578 114 Let's see your input! |
Re: What's the best cam for a 427 stroker.... that 232/236 is pretty small (I would run it in my 346 if P-to-V would not be a problem...) :devil: I also vote something in the mid 240s....that seems to be pretty common for engines with 400+ CIs... |
Re: What's the best cam for a 427 stroker.... From experience I can tell you that the Comp Cam 242/242 - .612/.612 will idle and drive without issue. [/quote] 505/500 Basic engine specs... 4.125" bore x 4.000" stroke LS6 castings 11.25:1 here's a link to some pics of the build.. 427 Build Up |
Re: What's the best cam for a 427 stroker.... S1. You already know the potential in those heads with this cam. Tony |
Re: What's the best cam for a 427 stroker.... Go with MTI S1 cam that i run in my 427 A4 with specs of 244/244, .612 lift on a 112lsa. On my A4 i have never stalled on the street and the cam makes huge power and with your M6 tranny you should be golden. :eek2: :drive: |
Re: What's the best cam for a 427 stroker.... MTI 427 CID, how are your hot starts? |
Re: What's the best cam for a 427 stroker.... Go solid roller :devil: I can drive mine without issue (except some 2-footed driving while cold), and it makes every cam on this page look *tiny*. And yes, it is an auto, and I run my a/c a lot here in Texas. |
| All times are GMT -5. The time now is 10:05 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
