Truck 5.3L with LS7 cam
speedtigger, I don't see much about the Titan II cam you mentioned above.
I am considering this cam for stock LS1 with ls2 243 heads, I have ls6 intake and tb, and
I have fast cathedral truck 102/102, which intake would you recommend?
long tube 1 7/8
And any idea what the idle will sound like, will it sound like there is a aftermarket cam in it?
long tube 1 7/8
If you are looking for a heavy lope, hotrod type idle, I would suggest something else, but if you want a great all around performance daily driver camshaft, you will love this one.
~Steven
__________________
The Switch Is On To Cam Motion!
40 years of Championship Winning Experience • Superior 8620 Steel Camshaft Cores • Quiet, Smooth & Powerful Lobe Design • Virtually Unlimited Lift and Duration Combinations • Finish Polished For Quiet Operation • Cam Doctor Printout With All Cams
The Industry's Best Customer Service
www.CamMotion.com • ☎ 225-926-6110 • Like Us On Facebook!
Thanks for the response, idle sound isn't a concern, I was just curious. I guess my main
question is will the fast truck actually be beneficial to the cam, or is the ls6 all it will use?
I think the combo will definitely appreciate the extra flow/efficiency offered by the FAST.
__________________
Both LS6 and LM7 are Gen III. Both use rear cam sensor.
