dart 225 valve seal install
IF the seals are the same...
use a 12pt 1/2" socket.(not a 6pt)
listen closely for the sound to change when you're tapping them on. if you hit them after they've seated you'll bust the spring like i did....:o(
Originally Posted by oldschoolmuscle
i ordered the partriot extreme kit, but the seats where not big enough, so i exchanged them for there oversized one. so i take it the valve seals are different as well ?
