LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   what's the difference between the heads??? (https://ls1tech.com/forums/generation-iii-internal-engine/780626-whats-difference-between-heads.html)
CAMARO SS 2000 Sep 10, 2007 02:47 AM
hi
I'm going to buy the afr heads 225c 65cc chamber but I'm confused because there are two type of head
1- small bore
2- big bore
I don't know the different between them ? and which one is the better for N/A without turbo/Nos ?
vettenuts Sep 10, 2007 05:13 AM
The small bore are for standard 346 cu in engine, large bore is for larger bore engines. If you are buying AFR, just contact Tony and get all the information you need on the heads to make informed decisions on the heads and the options they offer (Upgraded valve springs, milling, etc.)
CAMARO SS 2000 Sep 10, 2007 08:10 AM
Ok how can I contact with Tony
can you give me his e-mail please ??
vettenuts Sep 10, 2007 11:34 AM
Look under the member's list, he is in there as "Tony Mamo". Shoot him a PM, but note that they are testing right now (according to his response in another thread) so it may be a while before he gets back to you.
© 2026 MH Sub I, LLC dba Internet Brands
