will my car run untuned with these mods
Stage 2 5.3 patriot heads 2.02 1.56. ls1speed comp cam 231-237 591 601 114+2 comp pushrods slp oil pump....not talking about driving...just wondering if it will idle with the stock tune after we get it put together. thanks
With the A4 it will surge and die at stop lights and things like that, Your best bet is to have it towed to the dyno. My friend did AFR heads and 224/224R 112 LSA cam and his car surged really bad at idle. At stop lights he would have to put it into neutral and feather the gas. When i did my car it idled well enough to drive to the dyno only about 40 min, but i have a M6.
Twiddle the idle screw on the TB. You should be able to get it to tick over, however be careful about driving it as your AFR will be all over the place. Mind you not sure how that will work on the A4. Wont the car try to pull away as it thinks its got throttle.
Best option is to either trailer it or get a mobile tuner to take a look.
