LS6 CNC ported Heads with G5x3 112 LSA?
I'm very close to purchasing a set of CNC Ported Stage 2 GM LS2/LS6 Cylinder Heads from Livernois Motorsports and a G5x3 112 LSA cam from LG.
Will i have to fly cut the pistons with this set up? I have a 04 Z06 if that helps any. Thanks In Advance.
P.S. I just found this site, there is some great info on the LSx engines, i have alot of infomation to collect from this site.
Patrick .
Patrick .
I am on the same boat you are, but i am half way through my cam and head install and should be done next week. I just need to port the heads, cam is already in. Though i am using the stock ls6 heads and porting them, i called LG and they told me i could run a .04 cometic gasket with the G5x3 cam on 112lsa with the stock heads, so you should not need to fly cut.
You could always wait till next weekend and see how my install goes, i will report back once i get her tuned and dynoed.
PS
My complete setup should be LG Pros, G5X3 112LSA, ls7 lifters, ls2 timechain, 25% powerbond pulley, and ported LS6 heads with PRC dual springs.
PS
Thanks for the reply!
I would greatly appreciate the progress on your heads and cam install. I'm looking to get this setup going a.s.a.p. I e-mailed LG saturday and haven't got a response yet, hopefully by tuesday.
Thanks, Patrick.
Thanks, Patrick.
I want LS6 CNC Ported Heads, If there is a better vendor with these heads, im all ears.
I know AFR's are one of the best, but i don't really want to spend over 2,200 for a set of heads, if i get 450+ RWHP with LS6 ported heads, i'll be happy.
stock head stock gaskets i measured my ptov and it was .070/.110 they said people recommand .80/.100 so i didnt flycutt. hope this helps you guys out i think you have to flycutt if you got the heads milled or used thinner headgaskets. livernois are good heads seen great results out of them i was goign to go with them but me being in college couldnt afford it
You need to flycut. The X3 on a 112 is right at the bare minimum saftey clearance specs. Add in a Stage 2 head (most likely milled and larger valves) with thinner head gasket and you're looking for trouble. If you decide not to flycut, please be sure to post the pictures after the damage has been done so we can have another fine example of WHY you should flycut when it comes to combo's like this. Good luck man
well I know livernois can build them without milling the heads, and they use production size valves so if the cam is desined to fit on a stock head then it should fit on a livernois head.
As tell everyone I talk to, check it anyways, hell I check stock cams on a stock head just to make sure i didnt f' something up.
I definately vote for running the stage 2 livernois head, great product and an awesome price. I have talked to Dave (in the cylinder head dept.) there many times, and watched him work, he's a mad man when it comes to head porting
Thanks for the replies everyone. I'm really on the fence here, i'm going with the Livernois heads because they are ported GM LS6 stock cores and i heard the G5x3 '112 LSA can be used safely on stock LS1/LS6 heads, please correct me if i'm wrong.
I was just going to do a cam swap with a Comp Cams 921 Kit, but then decieded to atleast get the LS6 Heads ported while i'm at it, if it is not safe with the setup im looking at, i will just stick with the stock heads for now.
I don't want to start messing with the engine itself, that's why i don't really want to flycut. I just want the bolt on mods as of right now. I really like the sound the G5x3 makes on a 112 LSA and the power it makes, like a C5-R (minus the 427 of course) .
I listen to this video on youtube almost everyday, even though its not a LG cam, it's pretty close to a G5x2:
Corvette C6 Cammed! http://www.youtube.com/watch?v=ud0hZ...elated&search=
Thanks, Patrick .
Thanks, Patrick .
I think the livernois heads are great. But I went a head and shelled out the $ for the AFR's so I would never have to look back. The x3 cam is awesome to. I had a 234/242 .591/.601 on a 114+4. I liked it BUT the power didnt really come on until about 4000 rpm's. Maybe due to the lsa.
I ran 5.3 heads with that cam, milled to 58cc's and a stock size gasket. I had to fly cut the **** out of the pistons also due to the lsa I think. I went a little over board .155" on int and .145" on ext. So I wouldn't have to do it again for the next cam which is a 236/236 .591/.591 110 lsa.
You will be happy with the parts you have listed.
To answer the post:
X3 on a 112 will fit stock casting ported heads only and only if:
Stock valves
Unmilled
stock gasket
Anything else is below safety margins, 112 X3 is allready very tight, like around .065>/070 on intake (Street speaking of course)
Stock valves
Unmilled
stock gasket
I was just looking for a cam only, but i said "what the hell might as well get the LS6 Heads ported".
I'm not looking for crazy power, if i was i would just do a whole engine rebuild starting with a C5-R 427. I don't want to go to crazy, because i would like to pick up a C6 Z06 in the future.
If i can get 425-450 RWHP i will be happy.
I'm now looking at the MTI X1 cam, it sounds wicked and i can use the LS6 heads with upgraded springs without a flycut. It's either an MTI or and LG cam with ported LS6 heads.
Again, Thanks for all the help .
sorry for the
