Question About Fuel Injectors
Here is one stupid question, what are the LS1 injectors stock? Aren't they 28#'s......
Anyways...
My duty cycle for my injectors with my 228/232 .588/.595 cam is 98% So i was thinking that i was going to upgrade to 42#'s. What is a good one to go with? SVO or isn't there one called red top or green top
Thanks
Anyways...
Thanks
I am in the same boat as you.
https://ls1tech.com/forums/fueling-injection/807096-new-fuel-systems-need-your-help-my-project.html
I plan on going with Racetronix's 42# Injectors (280) with their Plug and Play Setup for 249.99.
I had a used set of 36lbers from my old GTP sitting around and got 2 extra's from another buddy with a Regal GS for $20. They run around 40 lb/hr at 58PSI. The 36 lb/hr rating is at 50PSI. You can find them all the time on the ClubGP.com board when people upgrade to the 42 and 60 lbers on the 6 cylinder cars.
They are a stock GM injector for the Supercharged V6's and fit perfectly. I went from 98% duty cycle to about 68%
https://ls1tech.com/forums/showthread.php?t=807096
I will have to check it out..
