I have Eagle 6.125 rods, will these increase the Compression Ratio?
LS1TECH & Trucks Sponsor
6.098" is indeed stock length. 6.125" is the most common after-market rod length for these engines. The stroke, rod length, and compression height of the piston all have to be designed together to make sure the pistons aren't .050" out of the hole
To make this into a short lesson: (half the stroke) + (rod length) + compression height - deck height = how far pistons are in or out of the hole.
So a 4" crank, 6.125" rod, and 1.120 CH piston = pistons out of the hole .005" on a standard 9.24" deck height block.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Not really...several manufacturers make a 6.100" rod also that work with stock pistons and crank....that just pushes the stock piston another .002" out of the hole, which is fine in most cases.
__________________
OWN3D BY MY PROF!
I know it's only .002, but a few companies make forged 6.098 with both a .927 and .945 pin. Many companies also make forged pistons designed for the stock rods. I have a set of diamond 3.905 pistons, 6.098 rod, 3.622 stroke, .945 pin, with a 1.5, 1.5, 3.0 ring package. I'm going to be buying some forged 6.098 Scat H beams soon and put together a spare engine.
