Best cam for TSP 5.3 heads. choices inside
Im looking at pretty much going with either of these 3 to match a pair of PRC stage 2.5 5.3 heads from texas speed.
Thunder racing Reverse Split 227/224 .569/.563 114 LSA (would get custom 112 lsa)
Texas Speed 228R
Custom 228/230 600/600 112
It is for my 04 GTO. I will also have 3.91 gears done at the same time, maybe before purchasing a cam. I dont want to regret going too small, but i dont want the car to rattle my teeth out at idle.
I understand that shorter durations are better for these high compression heads bc 1- clearance and 2- they create better dynamic compression... if i am wrong let me know. Im shopping around right now so im open to new ideas.
I hardly ever go to the track, i just want a really fast street car... would like to put down as close to 440 at the wheels as possible.... is it doable with these ?
Other suggestions welcome, please state your reason for suggesting something different.
Texas Speed 228R
i'd go with the 228 or the 228/230
both should be very calm cams on the street with good tuning. and they will take advantage of the flow potential of the heads.
the first cam choice has pretty low lift.
I just put the TR230 reverse split in my car w/ the PRC 5.3 2.5's. The car made 422rwhp and 383ft/lbs thru a 9 inch w/ 4.10's and on a mustang dyno. Also have stock gaskets on there. Cam is super streetable and pulls thru 6500.
id go with the ms3. it does really well with those heads. just ask for the 5.3 heads and ms3 package, and they will also raise the valves on the heads so that the cam will clear without flycutting.
i say go custom cam. i did well am anyways. it suited my driving style better then the off the shelf cam. i got a lower lobe seperation w/ some advance ground in and a lil less duration so my numbers would be higher in the lower rpms rather then getting a cam that maxs where i wont use it. ( im not planning on revin over 6400 rpms ) and need power in the street for daily driving)
just my .02$
just my .02$
just my .02$
just my .02$
most of the cars ill run with will be boosted so they jump out pretty fast from a 40 punch. Id like to get more mid/top range snap out of the hole i think a custom may be in order
