Question: On LS6 from factory in f-body!! Ok I have been told that some 02's from factory had the LS6 block put in them. I was also wondering is if they came factory with the LS6 did they also have the heads, cam, internals, ect...? Jimmy |
only the block in a few last built |
Originally Posted by 00WS6WHITE
(Post 8183066)
Ok I have been told that some 02's from factory had the LS6 block put in them. I was also wondering is if they came factory with the LS6 did they also have the heads, cam, internals, ect...? Jimmy All LS1 F-Bodies in 01 and 02 have an LS6 intake. No, they never came with LS6 heads, or an LS6 cam. All internals such as rods, crank, and pistons.. are the same. |
Ok, thank you. Jimmy |
my 01 motor was an ls6 block, i heard that ls6 blocks have better rods bolts also but i don't know for sure |
Originally Posted by silverLSWON
(Post 8183154)
my 01 motor was an ls6 block, i heard that ls6 blocks have better rods bolts also but i don't know for sure no, the rod bolt upgrade was seperate.. very few 01's, and some 02's had the LS6 block.. the rod bolts were an assembly line upgrade in mid 00 and on for all cars. |
© 2024 MH Sub I, LLC dba Internet Brands
