how many people on here have actually had their heads flowbenched?
Old 12-03-2007, 02:46 PM
quiet_storm98's Avatar
Default how many people on here have actually had their heads flowbenched?
Just wanted to know if anyone has actually had their ported ls1,ls6,or 5.3 heads flowbenched after they bought them to see if they really flow what they say. I recently bought a set of 5.3 heads that were supposed to flow well over 300cfm but they only flowed 296. At first i was a lil dissapointed but the guy that flowed them said that is actually pretty good compared to the other ported factory castings he has seen. Believe it or not however he actually put a set of ls1 heads that he ported up there and they outflowed mine up until .400 inches of lift and the average cfm was higher and they only had a 217cc runner. Well anyway i would just like to see other peoples results. Also do certain flowbenches flow less?
Old 12-03-2007, 03:23 PM
NaSSty Nate's Avatar
Had mine flowed on diff benches. What bench did he use? superflow 600?
Old 12-03-2007, 05:44 PM
67Ranger's Avatar
Different benches flow different yes. They should all be within 5-10 CFM. The bench itself can also leak a little, and give different results. I have flowed some of the stuff that I ported, but never other people's work that I knew advertised numbers. Also, if they were hand ported they may vary 5-10 CFM from port to port.
Old 12-03-2007, 08:58 PM
yeah i believe it was a superflow 600...do they usuallly show lower flow numbers?? I wish i had another set of ported heads to compare them to, the only ones that i can are the ones that he ported which actually outflow mine until the higher lifts
Old 12-03-2007, 09:05 PM
99mongooSS's Avatar
what cam are you using with the heads?
Old 12-03-2007, 09:15 PM
a custom spec'd 231/233 .612/.598 111+2 lsa..luckily when they were flowbenched the flow peaks a lil after .600 inches of lift
Old 12-03-2007, 09:37 PM
99mongooSS's Avatar
so wouldnt your heads be better for that cam since it will be a higher rpm cam with higher lift number anyway? his heads are fine for a low end torque monster. My heads got flowbenched at TSP and they said they flow 310cfm at .600 lift I figure give or take 10 cfms that is still pretty good for the money. I wouldnt worry about what they really flow unless you got promised like 25 cfms higher than what you really got.
Old 12-03-2007, 09:49 PM
true..i was never thinking about buying the heads he has i am honestly just wondering if perhaps tsp, livernois, or something similar would flow better on his bench. He did say they looked like pretty good heads though when he looked at the ports even before he flowed them..they also outflowed his heads by quite a bit after .400 inches of lift but his heads flowed like crazy down low.
Old 12-03-2007, 09:56 PM
1LSWON's Avatar
Mine were flowed on different benches, and they flowed just like I was told, but mine were welded on etc.
Thomas
Old 12-04-2007, 07:41 AM
PREDATOR-Z's Avatar
Join the club, I had some advertised at 302 cfm .600 but only flowed 286 cfm.
Not to mention I no longer use that vendor. Too much dishonesty in their sales.
Old 12-04-2007, 08:28 AM
yeah i have heard from quite a few people that the advertused numbers are almost never what they see on flowbenches
Old 12-04-2007, 10:09 AM
Fireball's Avatar
my ETP 225s flowed a little lower than advertised on the int...but the bench was known to be a bit stingy
Advertised
Lift Int Exh
.100" 71 57
.200" 153 114
.300" 208 164
.400" 265 204
.500" 308 224
.550" 320 228
.600" 328 231
.650" 332 234
.700" 320 236
Actual:
.200 138.30 110.21
.300 214.30 160.68
.400 266.40 206.36
.500 302.54 222.37
.600 320.76 231.00
.625 327.09 -
.650 306.50 -
Old 12-04-2007, 12:20 PM
Flow Wizard
Tony Mamo @ AFR's Avatar
I have flowed alot of "330" CFM heads that barely mustered 310 (and some worse)....and some in the "low 300's" (so they were told) that were in the 280-285 range and occasionally worse. Not to mention there is alot of inflated exhaust numbers out there as well. The BEST LSx exhaust ports I have seen flow in the 250 CFM range at .600 lift....some are advertised significantly higher that flow in the 235-240 range (on both of my flowbench's....an SF600 and the one I built which I do most of my R&D on).
Welcome to the "real world" guys....LOL
Its good to independently check them....a small price to pay to insure you wont be chasing missing horsepower for a year scratching your head why.
Im sure you guys have seen my "flowthread".....that was posted to show you guys what the largest runner best cathedral port heads actually flow on the same piece of equipment with all the same flow fixtures, exhaust tube, etc. While the names have been withheld for obvious political reasons there is alot to learn from that information and it represents a ludicrous amount of time in total.
The bottom line is unfortunately most heads flow below advertised....some are just worst offenders than others and a small percentage are close to their published figures. When the 205's were first released we caught alot of crap about the fact they "only flowed 300 CFM", when the reality was at the time few heads regardless of their size actually did that (and the ones that did were 20-30 cc's larger).
BTW, AFR guarantee's our heads flow within 2.5% of our published figures (there has to be a small tolerance for production issues such as cutter life, CNC rotary and spindle conditions, etc.). Some actually flow more than we advertise....but in general our published figures are very close and most shops without an axe to grind with our company will verify that.
In short....Everyone serious about making power should have their stuff verified. Its the only way to really know and I include our product in that statement as well. In our case if something is wrong (unlikely but occasionally it happens) we will stand behind it and either get your head up to snuff or replace the casting.
Im off to PRI....will follow up with this thread later.
Regards,
Tony
Old 12-04-2007, 12:32 PM
PREDATOR-Z's Avatar
And that is the "Blue Pill" of reality
Just to add, you get what you pay for, sometimes the extra $$ spent is really worth it.
One of my favorite wisdom is as Tony mentionned:
1- Have your heads flowed independently
2- Always inspect your products thoroughly
3- Only choose your cam once the real flow numbers are in your grasp
Mark
Old 12-04-2007, 01:09 PM
cdoggy81's Avatar
"Im sure you guys have seen my "flowthread"
Link...
Old 12-04-2007, 01:52 PM
miami993c297's Avatar
Link...
Seat down, relax and good read:
https://ls1tech.com/forums/showthrea...323&highlight=
Christian
Old 12-04-2007, 04:59 PM
MJD
MJD's Avatar
Heads done by Creative Flow Management. 241 cast with stock valves:
lift in ex
.100 77 65
.200 145 116
.300 199 159
.400 243 190
.500 275 210
.600 285 216
Old 12-04-2007, 06:02 PM
thanks for all the info guys..now that i see the flownumbers others have had i see that my results are actually pretty good..I figured that they wouldn't flow what they claim but i thought they would at least be a lil over 300 but i see now that 296 isn't all that bad. Also tony that is a great thread you have on the flow numbers.
Old 12-04-2007, 06:09 PM
Jordan S.'s Avatar
I did.
Old 12-04-2007, 06:38 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I plan on taking mine soon, but don't have any money. Is there an easy way to burret the runners and figure out the sizes?
Quick Reply: how many people on here have actually had their heads flowbenched?
