LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   which cam and gasket for PP 243's ?? (https://ls1tech.com/forums/generation-iii-internal-engine/830080-cam-gasket-pp-243s.html)
jzzamesb Dec 14, 2007 12:58 PM
I have decided to go with Patriot's 243 head and either the f13 112 or tr230 111 cam. I've heard 11:1 compression is what you need for street use on pump gas (93) Will I need to mill the heads any or use a thin gasket to reach this?? All help appreciated.
gtorep Dec 14, 2007 04:04 PM
I used the Thunder racing TRak cam 231/234 .640/.590 112 LSA, with a .051 cometic gasket with mine, I also use the 243's with the 59cc chamber, static compression is like 11.3 to 11.5, DCR comes out to 8.38 I believe, runs fine with 93 octane, has zero knock and pulls like a S.O.B, should have it dynoed soon.
hope that helps?
JPH Dec 15, 2007 03:43 PM
230+ duration @050 and use 11:1 min. compression, for best results.
PREDATOR-Z Dec 16, 2007 12:05 AM
I think you would be pleased with either, TR230 will make a bit more undercurve due to the valve events, FM 13 will pull a bit more on top.
gtorep Dec 16, 2007 12:51 AM
I happen to have a TR230 for sale. Hes right about power under the curve, its an awesome all around performer.
© 2026 MH Sub I, LLC dba Internet Brands
