Head Question: Attention Head Guru's And Patrick!
Old Dec 21, 2007 | 09:19 AM
beanx's Avatar
Default Head Question: Attention Head Guru's And Patrick!
I have found 3 sets of heads they are all pretty good deals i think but im not sure which set is the best. What are your guy's opinions. My mods are in my signature and i plan on doing a small mild cam later on down the road but not anything to soon. I would like to buy the set of heads that im going to see the biggest performance increase from even if i would have to mill them or do some other kinda machine work to them. But what are your guys' thoughs? Thanks in advance!!!!!!
*EDIT*
And if it helps here is a link to stock LS1 head flow numbers and some other information here, http://www.smokemup.com/tech/ls1.php. Also here is a link to Patriot Stage 3 Heads, Patriot Stage 2 Heads. I Guess you could do some comparing between them and stuff with the first set of heads. Thanks alot guys i apriciate it!
Set #1
5.3 heads that are stage 2.5 ported by Vinci racing. intake valves is 2.02 exhause valves are 1.60
$930.00 shipped
Set #2
TEA Stage 1 heads 62cc with 2.02 and 1.55 valves. No flow chart guess the guy put down 430rwhp though.
$500.00 shipped
Set #3
2.00/1.55 inch valves PRC Stage 1 LS6 CNC Ported Heads beehive ls6 springs milled to 58cc 243 heads.No flowchart but guy claims 400ishrwhp with these heads.
$850.00 shipped
Old Dec 21, 2007 | 11:27 AM
99mongooSS's Avatar
I have a set of the prc heads and they are good pieces. I made 440rwhp with those heads and a MS4 cam
