do i have all my parts for the cam swap?
Comp 232/234 .595/.598 110+3
PRC Dual Valvesprings, seat, retainers and valve seals
New GM valve locks or keepers
Texas Speed 7.425 pushrods
LS2 timing chain
Melling 10296 oil pump
pick up tube o-ring
GM timing cover
GM water pump gaskets
GM crank bolt
GM front main seal
Ngk spark plugs
Pulley install tool
pulley remover tool
crane valvespring compresser tool
5/16" 2ft dowels for lifters
blue loctight
brake clean
antifreeze.
LS2 timing chain
pick up tube o-ring
GM timing cover
GM crank bolt
GM front main seal
Ngk spark plugs
Pulley install tool
pulley remover tool
blue loctight
brake clean
antifreeze.
Get a new O ring for the oil pump pickup. An LS2 timing chain is a good upgrade for low $$. Ls1howto has a nice list:
http://www.ls1howto.com/index.php?article=23
