Camaro Z28 2000model M6
Engine Stock bottom end new rebuilt Cam G5X3 Heads Patriot Ls6 stage 2 (2.02/1.57/59cc) Morel Hydraulic Lifters LS1 with Link Bar Setup (92mm FAST Intake and Nick Williams 90mm TB)
Headers Long Flowtech Y pipe With Electric cutout
Gear M6 Stage 3+ Package with flywheel
Read End Richmond 3.42 Gear Eaton Posi 28 spline unit TA Performance Rear-end Girdle.
My last set was the same with out the morel lifters, Fast intake and a 3.7 rear end which made 447 Rear wheel Hp.
Does this look ok this should be finished today ill break her in and then send some dyno results.
Next time I will do the same but on an Ls2
