What's the torque spec for heads? like the title said whats the torque spec to tight heads on LS1? the long studs and the short ones help ASAP |
80 LBS if you use the ARP moly lube, I did 85 though. No leaks through the cometics. |
yeah my friend is using ARP studs so 80-85 LBS is enough |
Originally Posted by Camaro01SS4life
(Post 8917453)
the long studs 80 LBS and the short ones too? the heads are AFR |
| All times are GMT -5. The time now is 11:49 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
