I'm about to replace my head gaskets and only want to do it once! A few questions....
That is interesting. I used to run a high comp atv (14:1 static) and used copper spray on cometics and was still blowing the heck out of them. I've had a bad taste in my mouth about them since...
I guess I should've used some type of spray or sealer on my cometics, cause I know for sure they are leaking. I just put them on about 3months ago and it kinda pisses me off cause I made sure my deck surface was absolutely clean. I went over it a couple times making sure there was nothing on the deck surface and heads were just decked so they had nothing on them. I pretty much gave the gaskets no reason to leak and they did. Yeah well, if it starts getting to the point that it lets oil on the floor I guess I get to pull heads off again.
