How many of you ACTUALLY degree your cam install?
I'm wondering... I'll have the heads off, so it's be easier to find TDC w/ a depth micrometer (Forgot the name)..
The cam.. 224/228 .637 .639 110+0
I know it's just insurance to be sure everything is working properly, but I'm not a PRO builder..
Sorry if this is a stupid Q..
Even if you degree it and have a stock timing set, there's no adjustment. That's like changing out the heads and measuring the bore size of your stock motor, just to make sure.
We dot-to-dot'd -=MOD=-'s MS4 and that thing still runs like a champ.
Good point.. I've heard that the MS4's have actually been degree'd close to 109 LSA...
On a side note, would my stock timing chain be OK to re use?? What's it good to?
1 Post
The dots are there for a reason.... line them up and move on
(some) People are woried about as little as half degrees....but use a used stock single roller timing chain. Thats like wiping BEFORE you ****.......it makes no sense.
the only way you could **** up going dot to dot was if the dot on the bottom wheel was off and didnt represent TDC #1, in which case you motor would be running like **** if at all before you tore it down. I could see degreeing the cam being important while building a new engine that hasnt been running before though, just to be sure you didnt **** something else up. Or you could be a dumbass and think that dot to dot means perpendicular or some ****. Or adjustable sets, like stated above.
