rebuild suggestions/questions - LS1TECH - Camaro and Firebird Forum Discussion
Thread Tools Search this Thread
Old 05-12-2008, 02:14 PM   #1
Default rebuild suggestions/questions
I'm building my '02 ls1 to go in my '98 z unstalleda4. This will be a daily driver with stock exhaust. I've got the bearings picked out to order but I still need piston rings. Going to use to stock pistons because it only had 38k miles on it. Block was honed and had new cam bearings put in. Where can I get stock rings or do you think I'll need some bigger than stock?
My other question is for the cam. Thinking of running the 224 cam on the 114 LSA with some 918 springs. I've got some 853 heads that I'm going to run. The car will be daily driven with minor street usage. Would another setup be better or would this run ok? I know you're going to say put a stall in it but it will eventually be a 6-speed car.
Any other suggestions/comments?
ss69 is offline   Reply With Quote
Old 05-12-2008, 02:17 PM   #2
Grimes's Avatar
if it's a daily driver, the 224, it is a great cam for haulin around town .
One suggestion, definitely upgrade the pistons at least. I think Mahle makes stock piston upgrades that are forged. Don't put the stock ones back in, you'll only regret it later.
Grimes is offline   Reply With Quote
Old 05-12-2008, 03:49 PM   #3
I figured it would be ok since it won't be sprayed at all and normally won't see more than 10-15 miles per day except on the weekends.
Old 05-12-2008, 11:48 PM   #4
So does this sound ok? And what about the rings?
Old 05-12-2008, 11:55 PM   #5
ss.slp.ls1's Avatar
If you not gonna push crazy hp, you should be fine to use the stock pistons, and if all you got was a hone, standard size rings will work.
ss.slp.ls1 is offline   Reply With Quote
Old 05-13-2008, 12:19 AM   #6
Thank you sir. No crazy numbers for me. Just something to play with a little.
Old 05-13-2008, 09:55 AM   #7
Which version of the 224 cam would be the best for my setup? Or would another cam work better?
Old 05-13-2008, 10:06 AM   #8
ss.slp.ls1's Avatar
The TR224 is a good cam for all around power, this should work very well with your plans/usage. The choice of lsa is up to you (112 or 114).
Old 05-14-2008, 12:25 AM   #9
are either of the two worse on the valvetrain or is it just choppier idle? And which lobes? the xer lobes? I'm going to get the ls7 lifters.
Old 05-14-2008, 01:10 AM   #10
HottLS1Z's Avatar
112 will be a choppier idle then 114
HottLS1Z is offline   Reply With Quote
Old 05-14-2008, 01:20 AM   #11
Fifedogg's Avatar
TSP's 224R on a 112 LSA is a killer cam. But if I was you I would spend the money on some good pistons and put in some ARP rod bolts while you got the thing apart.
Fifedogg is offline   Reply With Quote
Old 05-14-2008, 01:29 AM   #12
gold98Z28's Avatar
new arp rod bolts for sure, but absolutely no reason to waist money on pistons. as for clearance on the rings, and the hone, this need to be acuately messured.........
gold98Z28 is offline   Reply With Quote
Old 05-22-2008, 12:46 AM   #13
But using the stock pistons with a hone will be ok? Are there bigger rings that will fill in the gap that will take up the space that was honed or how does that work?
Old 05-22-2008, 02:41 AM   #14
gold98Z28's Avatar
well you shouldnt blindly hone it. you need to measure the clearance on the pistons and see if it is in spec or not. if not then go ahead buy oversized pistons and bore/hone to match the piston. you dont match parts to the block, you match the block to the piston. if you just cleaned it up with a light hone and there was no ring groove then you should be fine..........
Old 05-22-2008, 10:18 AM   #15
Yea there was no ring grooves and it was only a very light hone. When you say you should be fine does that mean with stock rings?
Old 05-22-2008, 10:30 AM   #16
ss.slp.ls1's Avatar
With a minimal hone you "should" be able to use standard size rings, but everything should be precisely checked during pre and final assembly.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
