Anbbody USED The MS4 w/AFR 205cc Heads
Old 06-15-2008, 04:43 AM
allngn_c5's Avatar
Originally Posted by DannoWS6
AFR 205's would be a great match for a 383. Friend is running them on his stroker and runs high 10's w/ a M6. In fact I have future plans of re-using my 205's on a 402 build at some point. Might sacrifice a little top end but it will have a great curve.
+1 on this.
I have a 402 short being built. Most of my parts from the 346 will be swapped over. The smaller haeds will hurt topend numbers, but low/mid torque should be amazing. A bunch of members already have done this. Numbers varied depending on cam etc etc
510/490 to the wheels are some of the results I remember.
Old 06-15-2008, 07:33 AM
Restricted User
socmguy's Avatar
If you went with that H/C, your intake would really be choking your setup. A FAST 90/92 will put down over 25 more hp to the wheels on that combo.
Old 06-15-2008, 08:42 AM
SyndicateRacing's Avatar
Ok guys so should i go with the 205cc or the 225
Old 06-15-2008, 11:06 AM
BriancWS6's Avatar
Originally Posted by Paint_It_Black
I think you're putting your definition of "driveability" in the mouth of the people who DO run that cam and call it "driveable." A cam with that much overlap is going to surge in a 346, I don't care who tunes it, it's not going to drive like stock. There are a lot of perspectives on "driveability" don't assume everyone means the same thing when they say it. To some, it's driveable if they can manage to get it down the street.
I never said it would "drive like stock". I never even said how drivable it would be at all! I DO know however, that adding some compression with a good set of heads will improve the drivability compared to the same setup with stock heads/compression, AND, that an idle below 1600 resulting in surge, is not tuned to potential. I have a buddy that runs an MS4, he daily drives it and his idle does NOT act as described. And further more, the poster of that says it was even in a six liter car, which as we all know, should make the cam a bit more tame than in a 346.
6th gear doesn't count.. my grandma can tune a car to putz along in 6th gear. How is it in 1st gear idling around at 1000-1200 rpm? or idling around a parking lot IN GEAR?
Again, noone claimed these statements! We all know that the bigger bumpsticks are gonna be tempermental when compared to the smaller cams, but this argument is about how someone is having idle surge anything below 1600 rpm, which isn't typical.
Old 06-15-2008, 11:30 AM
AU N EGL's Avatar
205. 225 are for big cubies
You could put the 225 on yoru 400 and it will give you great upper power, but you might have a lot of throttle lag at the begining.
the 205s on your 400 should be a rocket ship, with great and immediate throttle response. May not give you the bench racing high hp numbers, but who cares.
Quick Reply: Anbbody USED The MS4 w/AFR 205cc Heads
