LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   Engine tech q's (https://ls1tech.com/forums/generation-iii-internal-engine/946795-engine-tech-qs.html)
WatchDogg Jun 30, 2008 09:04 PM
Engine tech q's
I have a 02 firehawk with a cracked block. I was thinking about throwing in a lq9. My question is will my stock heads and intake fit this engine, and are there any weird sensor issues I will encounter. What gaskets are going to be needed as well. Thanks again,
Tony
99blancoSS Jun 30, 2008 09:05 PM
Yes your ls1 stuff will swap over.
WatchDogg Jun 30, 2008 09:32 PM
Would I need anything special? Sorry for all the lame ass questions, but all of my other hot rods were blue oval powered. So now that I have switched from ford to chevy, I really dont have a handle on what interchanges yet.
KCS Jun 30, 2008 09:54 PM
Just about everything swaps over. All you would need to do is drill and tap a hole in the front the block for the P/S I think. The 6.0L blocks usually don't have this hole, while the aluminum blocks do.
© 2026 MH Sub I, LLC dba Internet Brands
