pro's and cons between 112 & 114 LSA what are the pro's and cons of the 2 LSA's? all i know is that the 112 sounds way meaner and the 114 sounds more stock, but what is the difference in performance? thanks! |
Re: pro's and cons between 112 & 114 LSA I believe, a 112 will make more power at a lower rpm. The 114 will push it up the rpm range. Tommy :) |
Re: pro's and cons between 112 & 114 LSA 114 is better for emmissions. |
Re: pro's and cons between 112 & 114 LSA The 112 will produce more power from the midrange to peak. The 112 will also produce its peak hp at a slightly higher rpm than the 114. It's a misconception that a 114 LSA will make its power higher up. If you can tolerate a rougher idle, get a 112 over a 114. |
Re: pro's and cons between 112 & 114 LSA How does one or the other effect the torque curve. |
Re: pro's and cons between 112 & 114 LSA I believe, a 112 will make more power at a lower rpm. The 114 will push it up the rpm range. Tommy :) you have it backwards.... :) 112 LSA makes a narrower/tighter power band with a higher "peak" power (on a dyno it will give you more hp) 114 LSA makes a broader/longer power band with a lower and later "peak" power ex: 112LSA power band: 2000 RPM - 6400 RPM with 445HP @ 6000RPM 114LSA power band: 1800 RPM - 6600 RPM with 440HP @ 6200RPM |
Re: pro's and cons between 112 & 114 LSA A tighter LSA falls off quicker after it's HP peaks. Take a 224/224 110 and a 224/224 116. All other factors being the same, you'll be shifting the 110 at about 6300 and the 116 at about 6800. The 116's power curve will fall off VERY slowly after the peak HP as compared to the 110. |
Re: pro's and cons between 112 & 114 LSA now i get it, thanks for the help people! :cool: |
Re: pro's and cons between 112 & 114 LSA I believe, a 112 will make more power at a lower rpm. The 114 will push it up the rpm range. Tommy :) you have it backwards.... :) 112 LSA makes a narrower/tighter power band with a higher "peak" power (on a dyno it will give you more hp) 114 LSA makes a broader/longer power band with a lower and later "peak" power ex: 112LSA power band: 2000 RPM - 6400 RPM with 445HP @ 6000RPM 114LSA power band: 1800 RPM - 6600 RPM with 440HP @ 6200RPM OK, I reaching now! :emb: Tommy |
Re: pro's and cons between 112 & 114 LSA i only let mine shift around 6450 and its 114LSA. Also, I dont see there the 112 is WAYYY MEANER than the 114? They both sound the same side by side to me. Just depends on idle rpm;) |
Re: pro's and cons between 112 & 114 LSA Yeah, 2 degrees doesn't really make that much difference. |
Re: pro's and cons between 112 & 114 LSA Is there any connection betwene overlap and surging on the freeway. |
Re: pro's and cons between 112 & 114 LSA I bought an MTI X1 because of the very broad torque range and Broad HP that is assosciated with it....It should also put up bigger peak #'s because of being 112lsa Is anybody here a shop guy that has done and dyno'd a ton of these to give a REAL ANSWER.??? |
| All times are GMT -5. The time now is 05:39 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
