LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   thoughts on a 228/232 .580'ish 112 ? (https://ls1tech.com/forums/generation-iii-internal-engine/95096-thoughts-228-232-580ish-112-a.html)
BLKWS6 Aug 21, 2003 02:36 PM
This was suggested to me to go with my TEA 1.5's (5.3) heads. What do ya'll think about it?
havent seen anybody with this one. And i like something really lopey too. :D
so many cams....so little time....
BLUEBYU Aug 21, 2003 03:00 PM
Re: thoughts on a 228/232 .580'ish 112 ?
This is the same setup I have been looking at....this time I am not going to be the guinea pig... I think it will be an awesome cam. I think going with an XE lobe on the exhaust will be sufficient and should put the lift around .575. Keep the intake XER with a .588 lift. You also may consider a 113 lsa (+3).
BLKWS6 Aug 21, 2003 03:14 PM
as far as the lsa....i would want it on a 112 or maybe even a 111 :devil:
BLUEBYU Aug 22, 2003 08:59 AM
That is fine....but put ICL at 110.
BTL FED Aug 22, 2003 09:09 AM
I am running a 228/234 588/598 112 +4 in my A4, I love the cam. I went from 289 rwhp (stock convertor), to(added a cam and longtubes) 359 rwhp, the convertor (TCI 3500) was dynoed unlocked , and my airfuel dipped below 10 to 1(pig rich), so I know I could get easy 37?'s out of it with an Ls6 intake, and a little work on my tunning. not to shabby for a cam only A4!
© 2026 MH Sub I, LLC dba Internet Brands
