LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   How much can u mill 853's (https://ls1tech.com/forums/generation-iii-internal-engine/952878-how-much-can-u-mill-853s.html)
95FbFormula Jul 12, 2008 11:22 AM
I have a 6.0 lq4 using stock replacement pistons 4.010 bore looking to get as much compression as I can out of it with 853 heads.
Shawn MacAnanny Jul 12, 2008 05:46 PM
.030 i believe. I'm pretty sure you need to use 3.905 gaskets and not 4.010 too.
chpmnsws6 Jul 12, 2008 08:13 PM
I pulled .050 without any ill effects
camaro 1999 Jul 13, 2008 02:02 AM
i bought a car and the ad when i bought it said that the car has stage two heads on it but the casting on the front say 853 can i check this somehow?
quikrnmost Jul 13, 2008 02:16 AM
.050 is as far as I would take it. I know .035 on mine is fine.
cdoggy81 Jul 13, 2008 11:16 AM
chpmnsws6,
Did you have to mill the intake any to get it to fit ok?
Shorter PR too I assume.
chpmnsws6 Jul 13, 2008 12:32 PM
Didn't have to angle mill it, and yes, I ended up with a 7.350 PR
cdoggy81 Jul 13, 2008 09:10 PM
Cool, that's what I did with my 241's :)
© 2026 MH Sub I, LLC dba Internet Brands
