cam swap, now doesn't start. Just like the title says. I did a cam swap, not it doesn't start. It cranks fine. But I have no fuel or spark, and my fuel pump doesn't run. All fuses are fine. Any idea? I had the intake off, but didn't disconnect cam or crank sensor. |
did you connect the coils and injectors? and you primed the pump to pressurize the rails,right? how many times did you try and start the car? |
Yes to all. The pump doesn't come on. I'm thinking PCM related, but I didn't touch it at all, or the wiring. I tried it a bunch. |
| All times are GMT -5. The time now is 05:22 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
