Better block Iorn or aluminum?
Thinking about options for a new motor if and when my motor goes. Only thing I dont know is which is a better material for a motor that will be 90% dd 10% track car.
Iron is more durable/stronger than aluminum thats just a fact. But thats not to say an aluminum block wont last either.
Best bang for the buck is an LQ9 408, the block is $300 less than an aluminum ls2 plus you need a conversion kit for the ls2 if you have an ls1. The ls2 403 is 4.005 bore x 4.0 stroke while the lq9 408 is 4.030 x 4" stroke or if your not going to use a power we add we do a 418 with the LQ9 for an even better CID/$.
That is why I will either just stroke my current block to 383 or go 402 But I know a couple guys spraying a 150 shot no probs on LS1/6 blocks. As Blanco says if you want more cubes than 402/3 you will have to go iron (or LS3/ LS7).
i think it ultimately depends on appliocation and power goals
id say n\a and under 700 hp can go with alumn
but
power adders and high hp should go with iron
75lbs only takes max 10-15 hp to compensate for so solong as were talking drag car id go iron
also keep in mind iron blocks usually need bigger radiators so i really dont buy the cost difference argument....
either way youll be happy just think of your long term goals before decideing
but
For me it is not the extra weight it is where the weight is. I like the twistys and don't want any more weight over the nose. One reason our engines are set so far back under the cowl was to improve the front to back weight ratio to make the car handle better. If I wanted an all out drag car HELL YEAH I would go iron!!!!
All good points. I went with a sleeved LS2 but I have 5 iron blocks in the works right now for customers all running street cars.
You don't need a radiator swap so lets squash that right now. There is about a $600 cost difference between the two when all is said and done. Some prefer to save that $600 and put it into a new rear. You can also get more power from the bigger cubic inches.
If money wasnt that big of an issue our LS3 416 is a great way to go!
Moderator
K-member and A-arms does not add up to 50lbs savings. Battery is nowhere nera 25 lbs savings either, so the 75 lbs is a lot. Pluss $1K for K-member & A-arms beats out the $600 for the cost difference in the aluminum block.
It's an opinion, and either way you decide to go is up to you. If I were looking for 1000rwhp turbo, I would go iron, N/A or some FI Aluminum.
Show me some pic's of engine's that failed because of the aluminum block. Everyone always argues that iron is better because it is stronger. No doubt iron is stronger but I've never seen anyone say "yeah I hit xxxx rwhp and the block split apart". The point is the block doesn't need to be made out of iron when aluminum holds up just fine.
Show me a cheaper way to save 75#'s on the front end. As Dave said a K-member and A-arms cost more for less weight savings. Not only that but if you are going all out with weight reduction you will have the K-member and A-arms anyway so you are still 75 pounds heavier with an iron block.
I just haven't heard of enough people having block failures to argue that you need the extra strength of iron. I look at it as 75 pounds saved for 600$. Saying you went with iron because it wasn't worth the extra cost to save the weight makes since but saying you went with iron because it is stronger doesn't really make since when aluminum is strong enough.
-Joel
