TSP Goes Back to Engine Dyno with Stock 346 LS1!
Old 08-24-2008, 09:19 PM
  #61
B02SS's Avatar
How about showing the differance between installing any of these cams
dot to dot vs degreeing.I think that would be some useful info.
Brian
Old 08-25-2008, 03:46 PM
  #62
blu1's Avatar
I'd like to see something like this:
230/236 xe
230/236 xe-r
230/236 xfi
230?/236 lsk
Old 08-25-2008, 08:42 PM
  #63
jocko's Avatar
PERFECT TIMING,Im looking for a great head and cam combo and was just reading the article on the gm hitech from jan 07 when tsp uses the ms4.
Old 08-26-2008, 08:56 AM
  #64
Garrett114's Avatar
I would also like to see some sleeper packages put together. From reading some post people have been hitting the 400rwhp mark with cheatr cams and stealth cams.
What about the cathedral port heads yall were developing lets get some numbers on them.
Old 08-26-2008, 02:12 PM
  #65
gator's 99TA's Avatar
excellent idea and thread! the engine dyno makes the most sense. just most guys wont spend the money to do this b/c their "shops" are their own garage or their mom's basement lol
Old 08-28-2008, 02:21 PM
  #66
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Here's a little teaser for you all (full results in a couple days, we've got ALOT more dyno'ing to do): Stock long-block with baby cams and a FAST 92 intake going close to 500hp! 1 7/8" headers are making more power from start to finish of pull over the 1 3/4" on the stock heads/cam configuration with the FAST 92!
We're just getting ready to start testing different cylinder heads this afternoon. Full results maybe this weekend? If not early next week after we compile all the data!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 08-28-2008, 02:30 PM
  #67
TXZ28LS1's Avatar
sweet matt!! i really wanna see some 5.3 heads vs. some LS6 heads!! im looking at these heads for my setup.
Old 08-28-2008, 05:38 PM
  #68
00cls1camaross's Avatar
i would love to see a texas speed cheater h/c combo....
Old 08-28-2008, 05:41 PM
  #69
redchevytruck's Avatar
Default .
Sweet
Old 08-29-2008, 01:54 AM
  #70
N4cer's Avatar
Why would you do it on a 92mm and 1 7/8" setup? The most useful data would be obtained using the most common setup: LS6 intake and 1 3/4" longtubes. The way it's looking, you're doing more of a sales gimmick than a true test that would be useful to the masses. Just a thought.
Old 08-29-2008, 06:30 AM
  #71
Fratsit's Avatar
Subscribing
Old 08-29-2008, 06:43 AM
  #72
The Dragon's Avatar
Thumbs up
Now THAT'S what I'm talkin' about!
No surprise on the headers whatsoever; I know from experience the bigger headers make bigger power EVERYWHERE with the FAST Intakes.
Now . . . let's hear about the Adult cams and heads
Old 08-29-2008, 07:24 AM
  #73
UNDER PRESSURE MOD
The Alchemist's Avatar
That's interesting that stepping up to the 1 7/8 headers responds well to the FAST 92 intake. Makes me think that with my ported FAST 90/90 that my next set of headers might be a set of 1 7/8".
Old 08-29-2008, 09:34 AM
  #74
Two reasons: First, we have ALOT of people going to the FAST 92mm intake combos on relatively stock engines. This intake picks up power from idle to redline even on the stock long-block in the tests we've run. SO, it actually is good info for the masses that are curious what it does on the stock long-block and are on the fence about buying it currently.
Secondly, we are doing ALOT of different combos during this week of testing. We have not only tested cam only setups, but have been testing many different heads/cam combos including a cam or two of our competitors that random customers sent in to be tested. We did not need to add to the bulk data by testing two different intake manifolds as it would only cloud the end results of the testing. Having too many variables takes away from the credibility of the tests. Having the best supporting bolt-on mods on the engine dyno allows each combo tested to reach its full potential, whether it's one of our camshafts or a competitors.
__________________
Old 08-29-2008, 10:12 AM
  #75
01_torch_red_vette's Avatar
in the market for a head/cam package on the stealthy side... cant wait to see results
Old 08-29-2008, 01:09 PM
  #76
matts22's Avatar
I like that you are testing on a FAST intake (because like many people I have one). Are all of the tests done with 1 7/8 headers? I don't know if that is justified because not many people actually run 1 7/8 headers.
Old 08-29-2008, 02:08 PM
  #77
WSsick's Avatar
maybe this will show people that the 1 7/8 are a really good choice to match with the FAST.....and conviently, TSP just released 1 7/8 headers lol.
ONE STOP SHOPPING dumdumdum
Old 08-29-2008, 05:11 PM
  #78
chrs1313's Avatar
awaiting the write up...all tests were done using the same short block correct?
Old 08-29-2008, 05:22 PM
  #79
Engine_HP's Avatar
ms4 ms4 ms4
Old 08-29-2008, 06:05 PM
  #80
BREWS02WS6's Avatar
AND...things keep evolving so pretty soon we might see the 92mm and 1 7/8" combos as the norm...maybe.
Thank you guys for testing all this, it will definately be helpful for many people. Hopefully you guys or another sponsor can get some other results w/ the other intakes/headers in the near future. Or...we could all just in the dyno section because theres a bunch of those setups already out there.
Quick Reply: TSP Goes Back to Engine Dyno with Stock 346 LS1!
