springs on afr 205 heads???? You guys with afr 205 heads, are you using the regular afr springs that came on them or are you using the afr 8019 upgraded springs? What cam do you have??? |
8019's here. Cam is (or will be) the AFR 6016 (224/228). Running Yella Terra's. If you have questions on which springs to get, PM Tony. He can best advise you for your setup. |
If your looking for a set of afr 205s, I have a set with 5 minutes of run time & our springs installed on them! $2000 buys these bad boys! |
AFR 205's come with springs good to .600 lift. You can upgrade them to spings good for .650 lift. What spring you run is determined by what cam you run. |
© 2024 MH Sub I, LLC dba Internet Brands
