Running non-synthetic after synthetic??
First of all, my last few LS1 cars have been run with regular oil until h/c installs, then Ive switched to synthetic. My current project has run synthetic since new. When i do my h/c install next month, will it be ok to switch back to regular oil just for the break in, then switch back to synthetic? I just dont wanna waste money on synthetic for just a couple hundred miles. I only ask this because I read once that switching after a significant amount of time will cause problems with seals. Any truth to this? Would it be ok to switch back to regular for the break in, then switch back to synthetic?
LS1TECH & Trucks Sponsor
You shouldn't have a problem
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Because he is only going to leave it int eh engine for a few hundred miles and he doesn't want to spend the money on expensive oil just to end up changing it right away
__________________
I have only heard of running regular oil on breakin motors during the first 500-1000 miles due all parts breakin in. Once you run several hundred miles on the motor breaking it in at several rates of speed, than you can drain the oil and put in synthetic fluids and get it tuned. Again, I have only heard of this from several engine builders. That's what I did when I had my Olds. My .02.
Not true. Synthetic will not work for initial break in of piston rings. Dont think it will matter for swapping heads cam. The rings need to have enough friction to score the cycliner walls. Engines that come with synthetic from the factory had the engines broken in with regular oil before the where shipped to the dealer. In diesels synthetic is not used until after 15,000 miles to get a proper break-in.
You should be fine. On the day I took delevery of my 05 GTO the dealer told me it had Mobile 1 in the engine. I told him to drain the oil and install regular oil . IF I used the Mobile One the car would never break in properly. I went to Full Synthetic at around 2500 miles
11Second Club
I don't think that switching for such a short time will be a problem at all. I've always been told that the problem comes from using dyno oil for a long time (tens of thousands of miles) and then switching to synthetic. The dyno oil causes the seals to swell, and if you switch back to synthetic, then eventually they will lose that swelling, and the recession will cause them to leak.
So, if what I hear is true, then a couple hundred miles of dyno oil won't cause a problem.
TESTED , YES . BROKEN IN, NO
