Need help with compression and head gaskets!
Old Sep 29, 2008 | 11:27 PM
crzhrs's Avatar
Default Need help with compression and head gaskets!
I am rebuilding my Ls1 from my 2001 Z28. I will be using stock crank, rods and pistons. But I am adding a Stealth II cam 224/220 .581/.581 116LSA and stage 2 ported 243's. The 243's have NOT been milled.
Should I mill them or will this be enough compression?
Which head gasket should I use and what thickness?
Thanks,
Brian
Old Sep 30, 2008 | 12:09 PM
Chevy406's Avatar
With 66cc chambers and .056" head gasket SC=10.36 DC=7.73
With 66cc chambers and .040" head gasket SC=10.76 DC=8.02
With 64cc chambers and .056" head gasket SC=10.61 DC=7.91
With 64cc chambers and .040" head gasket SC=11.04 DC=8.22
With 62cc chambers and .056" head gasket SC=10.88 DC=8.10
With 62cc chambers and .040" head gasket SC=11.33 DC=8.43
The .056" head gasket is the GM MLS, and the .040" is a Cometic. I think that you would be conservative with 64cc chambers and a .040" head gasket, but if you have access to 93 octane gas, you could step up to the 62cc chambers with .040" gasket for a few more horsepower. The thinner Cometic gasket will improve your quench volume, which reduces detonation. Your camshaft is not quite optimized at 8.4 dynamic compression ratio. That profile has -10° overlap at .050" lift...
Old Sep 30, 2008 | 12:26 PM
69LT1Bird's Avatar
GM headgaskets are not .056, they are .052 compressed.
Old Oct 1, 2008 | 12:29 PM
crzhrs's Avatar
Thanks Chevy406, 64cc and .040 head gaskets sounds good to me. I don't want to run 93 if I don't have to.
