Heads cam intake for not so d/d 347 ls1
Whats everyones opinion on the best h/c/i combo on a forged ls1 alluminum block motor set for high compression an valve reliefs for a big cam. And what about a solid roller setup.? Looking for 500rwhp/400trq threw a m6 ls1 347.
What setup? Looking at big cam 110 lsa 650 lift, afr 225s/ ported ls6 intake or fast.. Any opinoins would be great, looking at power to 7k...
spider intakes with a top mount tb works better for 6800+ rpm motors. make sure your valvetrain is on point! dont use stock rockers if youre revving that high because you might see some float.
I'm at 11:4 CR, with TEA LS6 Stage 2 heads, unported FAST 92mm, and a 244/248, .62x/.62x cam. I'm currently at 460rwhp 6900rpm on a Mustang Dyno showing an 8kpa drop at that rpm. I'm also running through a full Kooks/Corsa exhaust. On a DynoJet I should be right at 500rwhp, probably even more if I get the intake ported, and swapped to a custom exhuast.
