yella terra non adjustables 1.8 on afr 225 heads..
Can I set the non adjustable yella terra like stock .Just set them to 22 ft pounds and thats it or do I have to do some find zero lash and then turn them 1/2 turn like old chevy lifters. I thought these were non adjustable.
Also would I need different length pushrods for 1.8 rockers on my afr 225s. the heads are stock and not cut. Running lingenfelter gt7 cam if that matters. And already checked the cam is fine with 1.8 rockers says so right on the cam card.
