What spark plugs to use on my LS2 setup! Please help ....
Hey,
I have a LS2 engine wih the following mods:
Cam: CompCam XER281HR with the recomended products (timing set, lifter kit, rocker arms, push rods, valve springs, retainers, etc ...
FAST 92mm intake
FAST 92 bigmouth throtte body ( cable driven )
FAST XFI Crate Engine Management Kit, LS2
FAST Transmission Controller & harness for the 4L60E
MSD Coils
Ported Heads
What spark plugs wuld you use with this ?
Thanks
Fabian
FAST 92mm intake
MSD Coils
Ported Heads
Thanks
Fabian
Thanks for the replies ...
I found the NGK at summits store .. but it says it is only for 2005/2006 LS engines.. mine is a 2007 Corvette engine .. will these fit also ?
Any other brand you can recomend or just the NGK ?
http://store.summitracing.com/partde...3+&appfilter=1
how do you define slightly ? the cam is a race cam and agressive and the heads are also fully portet ... should make nice HP.
I would run either the NGK TR55IX or Denso IT16 for this application. I'm running 11.31 SCR, Dart 225's, Crane 222/228 cam, FAST 90, Dynatech longtubes, and Crane rockers with NGK 6 heat range plugs (BKR6EIX-11, DO NOT use this part number for your heads, they are a gasket seat for Dart heads).
