L76 intake on L92
Old Feb 20, 2009 | 02:38 PM
MTtahoe's Avatar
Default L76 intake on L92
Anyone know what you have to changto put an L76 intake on a L92 motor? Do you have to use the car accessories instead of the truck ones, and is there mych of a wiring difference, as I have the L92 harness. I will get the computer tuned when it is in, but just wondered if wiring and acessories wise it would work...Also is the gain worth it?
Old Feb 20, 2009 | 10:17 PM
the_merv's Avatar
Veteran: Air Force
The Accessories would have to be changed, that's a given. I know that you would have to get Rails and Injectors aswell.
Old Feb 21, 2009 | 08:08 AM
tr_racing's Avatar
You will need the intake bolt too!
Old May 25, 2011 | 09:47 AM
musclemike's Avatar
Originally Posted by MTtahoe
Anyone know what you have to changto put an L76 intake on a L92 motor? Do you have to use the car accessories instead of the truck ones, and is there mych of a wiring difference, as I have the L92 harness. I will get the computer tuned when it is in, but just wondered if wiring and car accessories wise it would work...Also is the gain worth it?
thanks I was also trying to figure this out. Was stuck but not anymore.
Old May 26, 2011 | 07:42 AM
cam's Avatar
cam
The MAP sensor is also slightly different. The truck intakes use a clip over the top of the MAP sensor to hold it down but the LS3 uses a bolt in MAP sensor plus its nipple is slightly larger so the truck MAP fits too loose. Although the sensors electronically are the same to make the truck MAP work you need to fab up a small bracket to hold it down and use some o-rings or get crafty making up something to seal it. Either that or buy a new LS3 MAP sensor and go.
Read this theres pics and good info
https://ls1tech.com/forums/generatio...-manifold.html
Old May 26, 2011 | 05:12 PM
LS6's Avatar
LS6
Intresting
