ARH 1 7/8 headers and Y pipe pictures
Old 07-25-2009, 08:38 PM
LS6427's Avatar
JFM-jr,
Can you take a picture looking into the collector like you did with the merge? Thanks.
Old 07-25-2009, 08:49 PM
JFM-jr's Avatar
There is a velocity spike welded right in the center of the four primaires where they converge. It's real hard to see in the pics.
Old 07-25-2009, 10:32 PM
LS6427's Avatar
Thanks for the pics.
ARH did the velocity spike, right?
Old 07-26-2009, 07:15 AM
JFM-jr's Avatar
Yes ARH does that.
Old 07-26-2009, 01:43 PM
LS6427's Avatar
Yes ARH does that.
Whats the port for on the outside of the drivers side collector? 02 sensor? Bung?
I thought 02 sensors are always on the insides of both collectors????
Old 07-26-2009, 02:08 PM
LS6427's Avatar
Any reason 1-inch (or maybe just 3/4") can't be cut out from where you see my black lines? Ground clearance reasons.
It wouldn't effect flow at all, would it?
Reason I ask: I look all around my Grot 1 7/8" LT's, and if this 1-inch was cut out of them I'd have alot more clearance and I would never hit the ground like I sometimes do now. Both sides of my LT's can use this cut.
Old 07-28-2009, 04:47 PM
Jimmy P's Avatar
Thanks for posting the pics. I realy like the work of ARH.
Old 07-28-2009, 07:39 PM
Closed ex-Sponsor Account
Tom@ARH's Avatar
We put them on the outside of the drivers side header for routing and heat issues all our f-body systems are like that. The sensor will work fine on either side
Because they would hit the floor if we made them shorter there. we rarely hear of anybody dragging our systems they tuck up very high.
Old 07-28-2009, 07:42 PM
Tom@ARH's Avatar
What would happen if it had a 4" collector just wrapped around the 4 pipes cut off evenly after they come together and meet?
Also, what the port on that drivers side header, is that the 02 sensor on the outside?
I'm not following what your asking in the first sentence. And that is the O2 bung on the drivers header
Old 07-28-2009, 11:13 PM
LS6427's Avatar
How much space is between the top of the header and the floor pans on the F-Body?
I;m lowered with G2 Super Springs so any help I can get would be nice. I don't really hit alot but I'd hate to mess up some perfectly good NEW headers. If they were just 1/2" to 3/4" higher, I'd probably never hit them.
Old 07-28-2009, 11:20 PM
LS6427's Avatar
I guess what I'm proposing is to not have a venturi type velocity collector, just a straight pipe that tapers once right into the 3" "Y" pipes.
A round collector that wraps around the 4 pipes, and funnels down to 3". All brands of LT's taper down after the 4 pipes come together, then open back up to 3".
Has that ever been tested?
Old 07-29-2009, 06:15 AM
  #32
JFM-jr's Avatar
I will take a picture of that area for you.
Old 09-16-2009, 06:08 PM
  #33
wws699's Avatar
Couldnt be more happy with the fit of my ARH 1 7/8. I'll see if I can get some pic's this weekend. I have the ProKit and a newly Installed Iron 408 so the front sits lower than normal for now. Will be changing the shocks to AFCO double adjustable for a better drag setup
Spend the extra dough on good quality header, and a company that takes pride in their product.
Love the headers
WS6 Store ROCKS!
Old 09-18-2009, 08:22 AM
  #34
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,088 Likes on 716 Posts
Those look nice. Is the 4" merge an option available to all? I'll have to look into this exhaust setup for my 2000 z/28 project.
Old 09-19-2009, 01:15 PM
  #35
studderin's Avatar
PSJ, ther might be a PN on that but not sure if anyone would stock it. But Nick will make anything you wnat really, if you ask them.
I have had these same headers on my car for a few years now, still fit and look great!
here is some under car pics. (My I pipe in 4inch btw) The BMR trans Xmember is the lowest paint on the car, the headers have never scraped.
pic while building the Ypipe
done, driving like this for 2 years.
Quick Reply: ARH 1 7/8 headers and Y pipe pictures
